gusto Posted December 2, 2018 Report Posted December 2, 2018 Compression is good. If it was my motor I would do either of these two options. Do the bottom end internal upgrades and keep and weld the crank and port your stock cylinders. Cheapest option and you could still make great power. OR bottom end internal upgrades and new DriveLine 392 top end. Save your money and do it all at once. Quote
Banshee508 Posted December 3, 2018 Author Report Posted December 3, 2018 Compression is good. If it was my motor I would do either of these two options. Do the bottom end internal upgrades and keep and weld the crank and port your stock cylinders. Cheapest option and you could still make great power. OR bottom end internal upgrades and new DriveLine 392 top end. Save your money and do it all at once.Ok that was a cold comp test.And what would the bottom end upgrade Shift star mod, weld/true crank new seals/gaskets bearing?? And if i got a mild port would i have to rejet it And thanks for the helpSent from my iPhone using Tapatalk Quote
gusto Posted December 3, 2018 Report Posted December 3, 2018 Do t forget to check compression with throttle open. yes to all the above plus inspect and replace internals if needed. Yes to jetting change. some builders on here (HJR, DL, PowerLine) have a fast turn around. Shoot them an email for prices. Ported engine will really surprise you. Quote
