JUSTWANNARACE Posted June 5, 2018 Report Posted June 5, 2018 Clock the pingel to point more to the right side carb, left side pingel outlet to the right carb and right side outlet to the left carb. Run the fuel line on the left carb behind the carb body and down to the carb inlet. Should get you clear of the pipes at least that's what I've found on the cheetahs and the DMs Quote
sleeper06 Posted June 5, 2018 Report Posted June 5, 2018 Sorry I was eating chips. On a real note sully you should run a fulsboar dual chamber tank. They make two options, one you have to change the ice out frequently. The other has a built in ice machine for trail/dune machines Quote
Ayesully810 Posted June 5, 2018 Report Posted June 5, 2018 13 minutes ago, sleeper06 said: Sorry I was eating chips. On a real note sully you should run a fulsboar dual chamber tank. They make two options, one you have to change the ice out frequently. The other has a built in ice machine for trail/dune machines i have no idea what that is so i googled it and its showing me septic tank system lol Quote
Keno Posted June 5, 2018 Report Posted June 5, 2018 Get a double walled tank made. Fill one chamber with fuel, and the other with liquid nitrogen or dry ice. Doubles as a smoke machine. Quote
Ayesully810 Posted June 5, 2018 Report Posted June 5, 2018 5 minutes ago, Keno said: Get a double walled tank made. Fill one chamber with fuel, and the other with liquid nitrogen or dry ice. Doubles as a smoke machine. lol i thought sleeper was being serious until i look it up at first i was like wtf is that some og builder stuff or what?? Quote
Keno Posted June 5, 2018 Report Posted June 5, 2018 Idk who actually does it, but F1 cars can run fuel 10 degrees below abient. I read that a 10 degree drop in fuel is good for about a .5% hp gain Quote
salmon_slayer06 Posted June 5, 2018 Report Posted June 5, 2018 try a stainless steel spring and slide that over the hose. Same principle with the spring on radiator hose.... Quote
salmon_slayer06 Posted June 5, 2018 Report Posted June 5, 2018 I keep my gas cans in the shade and its more to do with preventing evaporating and keeping oil ratio exact.... Quote
ginger Posted June 5, 2018 Report Posted June 5, 2018 warm fuel causes pre-detonation and vaporization. hurts power and can cause you to technically run leaner. on top of losing power. granted im sure it isnt as big of a deal on pump gas as it is on race or alcohol. Quote
ZillaFreak Posted June 5, 2018 Report Posted June 5, 2018 There is no such thing as vaporation or pre-detonation. There is evaporation and vaporization. Then there is pre-ignition and detonation. Please know the correct terms. You do know that when the fuel vaporizes inside the cylinder, it actually lower the temperature and decrease the chance of pre-ignition. This is why direct injection is become very popular and allowing engine manufacture to run higher compression ratios. People need to understand, heat isn't a bad thing in engine. Maybe so can read up on this https://www.scribd.com/document/72372270/Vaporized-Fuel-Injection-System Quote
