Hello those wiser than I, starting to find time to get my 05’ back in the dirt after tweaking my stem. Bought a new Alba stem, pivot works bearings, and a new Chariot throttle. Short of keeping up w/ joneses I hope I’ve done ok.            Question: does anyone have any experience w/ CPI pipes and steering stabilizers? Wondering if there’s enough room, before I buy and go thru the return headaches. I’ve tried to read any posts, but notsure.Thanks for any grief I may be spared
What stabilizer? I can tell you everything you need to know about them.
CPI on what setup? Lots of things to consider there.
16 hours ago, trickedcarbine said:
Paging SheeRider11...
OP, are you on FaceBook? If so, hit up Robert Pierce. He has done it.
Thanks Tricked, will do that, could save a 100+ dollar mistake.
To keep things simple I’m thinking streamline carbon,not sure all the adjustability is needed for the price,maybe PEP,maybe?. On the front just received alba +2 stem-replacement,pro-taper909 7/8 bars,ff cut clean off(Nfg).Butotherwise stock suspension, hell,even the front tires are stock. Riding fast logging roads with water bars everywhere😜,knarly ROWs including rutted,washed out,boulder filled 3-4 gear climbs I have no damn business riding!  Keeping in mind I’m possibly  looking to pick up some decent a-arms and shocks if presented for reasonable. Problem is I’m 6’5” 230lbs,long reach,older than younger,and more aggressive than I should be. Does this help tfaith? And thanks much
