specialblend07 Posted May 23, 2018 Report Posted May 23, 2018 Sell it, buy a boat or something cool. 1 Quote
DirtyBP Posted May 23, 2018 Author Report Posted May 23, 2018 Is it smoking really bad out the right exhaust Sent from my iPhone using TapatalkIt’s just smoking bad in general. Checked the compression in both cylinders, they’re both right around 120psi. Sent from my iPhone using Tapatalk Quote
DirtyBP Posted May 23, 2018 Author Report Posted May 23, 2018 oh. yeah well if its sucking trans fluid into the pipe its most likely from the right side seal easy fix. like zilla take clutch cover off and pressure test the motor you should find the leak that looks like trans fluid I have two crank seals like 20 hrs on them only ill give them to you I ordered some already but I appreciate that Bro. Sent from my iPhone using Tapatalk Quote
Larry's Shee Posted May 23, 2018 Report Posted May 23, 2018 When you consider that the youngest it be is 10 yrs old, shit breaks, wears out, rubber deteiorates. Besides doing leak down before AND after, replace BOTH sides. Don't buy cheap seals. Quote
DirtyBP Posted May 23, 2018 Author Report Posted May 23, 2018 When you consider that the youngest it be is 10 yrs old, shit breaks, wears out, rubber deteiorates. Besides doing leak down before AND after, replace BOTH sides. Don't buy cheap seals.Any specific ones you’d recommend?Sent from my iPhone using Tapatalk Quote
