Baffled me on this one. So my compression is right. Great spark. Maybe to much fuel. But what's getting me is on the left side is good, the right nothing. But when you rev it's even then it switches sides then you rev, even then the left side. Alternates. What gives?
Sent from my SM-N920V using Tapatalk
2 hours ago, christoph.tamz said:
If so. How do I get it out?
take your pipes off and blow them out with an air compressor
I don't think that's it. I believe it's a dirty jet because I was running it last night and pulled the choke. Woke right up. Then I closed the choke and dead. Or maybe it's to small of a jet. I have 27.5s in there. 210 main.
what kind of pipes? if you have pipes that 210 is too small. unless you meant 310 btw what was your compression you said its good
140 it read. And cpi full exhaust. I called mikuni and they suggested 175 main and 55 pilot. According to them. 210 is to fat of a main.
Mind you I have 38mm carbs
175 main and 55 pilot? you don't have mikuni carbs nor did you call mikuni for jetting advise. Those numbers are keihin numbers. What carbs are you running? PWK38 or TM38?
Get some better info, it is very hard to help someone with no actual info.
