spdfreak98 Posted December 10, 2003 Report Posted December 10, 2003 well i took my carbs off and cleaned the heck out of them, checked everything and it was all clean. i adjusted the floats to spec and gas still pours out of the overflow. could the cold weather make the rubber to hard on the stopper? or could the o-ring on the needle valve be bad? Quote
psd1 Posted December 10, 2003 Report Posted December 10, 2003 I had the same problem with mine a while back. Found out that after cleaning the carbs I had failed to take the drain screw out, sand had worked it's way in there and the thing wouldnt shut off all the way. Give that a try! Quote
spdfreak98 Posted December 10, 2003 Author Report Posted December 10, 2003 well i went out and checked it..... and sure enough that was it.. it sounded like i had alot of dirt in there. thank u so much for the help, Quote
psd1 Posted December 11, 2003 Report Posted December 11, 2003 well i went out and checked it..... and sure enough that was it.. it sounded like i had alot of dirt in there. thank u so much for the help, Sweet, I finally helped someone...do I get 2 stars or something??? Glad it worked out. I thought it was strange that could happen when I hadnt even removed that drain screw. Scary how dirt can get into such small places!! Quote
