spdfreak98
    98 with fmf fatty pipes, power core2 silincers, v force reeds, wiseco pistons, k@n filter. boost bottle
spdfreak98's Achievements
  1. i was just kidding, i like this forum, but if u want u can bash me for alittle bit, i drive a 92 geo prism
  2. f*ck all of u
  3. well i went out and checked it..... and sure enough that was it.. it sounded like i had alot of dirt in there. thank u so much for the help,
  4. well i took my carbs off and cleaned the heck out of them, checked everything and it was all clean. i adjusted the floats to spec and gas still pours out of the overflow. could the cold weather make the rubber to hard on the stopper? or could the o-ring on the needle valve be bad?
  5. is anybody running the trinity 2-1 carb set up? if so do u like it, hows is the performance of your shee with it?
  6. thanks for the help guys, i'll get right out there when i get out of work.
  7. i have tried to adjust the float on one carb but it still poures out of the overflow, i even set it at like 25mm and it still doesn't seal. what should i do? i am stumped
  8. hey every one, i have a jetting ?. i have fmf fatty pipes with powercore 2 silincers, v force reeds, and a k@n filter. right now now i have 220 main and i think stock pilots. is this the right jetting? i live in new york and do not know the elevation so if you could just throw some suggestions out. thank you
