HELP
Damann
.How do you know when you need a new coil? Bikes has never ran beside 9 secs to find out it needed new crank seals, just had bottom gaskets seals and top end jugs pistons rings, and carbs rebuilt running stock pipes no baffles/packing, stock carbs, 290 main 27.5 pilot, floats set at 21mm, plus 4 timing, flywheel to pulsar gap a .010 thousands, business card gap,stock reeds, stock head, bike makes spark will not start, haven' tried dumping a shot of fuel into cylinders, idle screw 1.5 turns in from first touch of slide, air fuel 1.5 turns out. New spark pkugs, Bike wont start 😣, tired of kicking, What did I do wrong?
The bike has fresh rebuild bottom to top. I rebuilt it because when it did run for a short time, from me putting a shot of gas directly into cylinder, got it to fire.... all before bottom end rebuild.. now the whole motor is done, new everything, and I can not get gas into cylinders??? If there is then why not start. I have spark air just need fuel. Or my spark is not big enough... main question is.. how do you know when you coil is bad? Or not producing proper spark?
  • 2 weeks later...
