Drizzy Posted September 1, 2017 Report Posted September 1, 2017 Came across this and wondering if my shee will run better with this set up? And how you guys like it. Shee Runs good with my stock carbs this just looks easier to tune and jet. Â Â Sent from my iPhone using Tapatalk Quote
Drizzy Posted September 1, 2017 Author Report Posted September 1, 2017 Carb is good, manifold is garbage. As to running better, depends how you look at this. Mine single ran great for low end and trails, seen similar on other single carb setups too. Just doesn't have the top end power.I just basically trail ride and go to the dunes bout once a year. Don't want to sacrifice power on hitting that power band though. She hits it hard right now. It just seemed more convenient since your just messing with one carb and if I gained some power figured it was a win win. Sent from my iPhone using Tapatalk Quote
ginger Posted September 1, 2017 Report Posted September 1, 2017 why switch to a single and not run 2 small double? you change jetts often? thats the only benefit i see from a single is when it comes to changing jets.  Quote
Drizzy Posted September 1, 2017 Author Report Posted September 1, 2017 why switch to a single and not run 2 small double? you change jetts often? thats the only benefit i see from a single is when it comes to changing jets.  That was basically my question. If I would gain some power and only mess with one carb figured it would be a better set up. Don't really change netting that often and don't mind it. Just always a pain sometimes to have to get them re synced and fine tuned exactly the same. Sent from my iPhone using Tapatalk Quote
Drizzy Posted September 1, 2017 Author Report Posted September 1, 2017 It really isn't easier to jet. And you will gain power, but it will be lower in the rpm. Ya thinking I'll just stick with my stock carb setup and with pods Sent from my iPhone using Tapatalk Quote
ginger Posted September 1, 2017 Report Posted September 1, 2017 stock with pods, or if you want something a little less touchy, PWK28's are great thats what i have on my trail bike. 1 Quote
trickedcarbine Posted September 2, 2017 Report Posted September 2, 2017 10 hours ago, Drizzy said:  I just basically trail ride and go to the dunes bout once a year. Don't want to sacrifice power on hitting that power band though. She hits it hard right now. It just seemed more convenient since your just messing with one carb and if I gained some power figured it was a win win. Sent from my iPhone using Tapatalk  This seems to be the reason most jump to the 2/1 stuff. In the end, it is way more finicky. If you don't know how to get the stock carbs dialed in well, this will not be easier. Look in to making sure that carb has and EEK needle. Quote
Screaming Yellow Zonker Posted September 3, 2017 Report Posted September 3, 2017 I kept having problems with my stock 26's. I got a 2 into 1 (or some say 1 into 2) with a 38mm air striker carb and the damn thing runs 100% better. before I was emptying the bowls of all the fuel and now I have no issues. I have also gone to the dunes a few times and personally I didn't notice any power loss in the top end. I'm sure a dyno might prove me wrong.... Â Some love them some hate them. Quote
CiaranTRD Posted June 24, 2018 Report Posted June 24, 2018 Hi what size jets /needle are you running I have a 38mm keihin carb but don't know what sizes I need. Thanks 😊 Quote
