spurdy Posted August 15, 2017 Report Posted August 15, 2017 I don't think running a lockup clutch or not is going to affect shifting. However, the higher hp motor will make shifting difficult. I prefer a dunable override in my trail bike, but I have ridden both and still have one bike with a pro mod type trans that I cut years ago. Easy to do with the right tools but time consuming. Sent from my iPhone using Tapatalk Quote
SlowMoe Posted August 15, 2017 Author Report Posted August 15, 2017 I guess we will see. I'm gonna go ahead and order a driveline lock out and report back. I was just surprised by how much power my DIY ported motor made, didn't think it would overwhelm the stiff ass springs I put in itSent from my iPhone using Tapatalk Quote
RagunCajun Posted August 15, 2017 Report Posted August 15, 2017 I have a lockup with 6 stock springs. Engine makes 109/57. Mine is hard to up shift @ WOT but most people tell me i need to adjust the eccentric screw etc even though it seems to be fine. Apparently it should shift like butter even with a lockup with a lot of weight. Quote
SlowMoe Posted August 15, 2017 Author Report Posted August 15, 2017 Here's what I don't get. This is a 4 mill serval with no lockup and it ain't slipping.Sent from my iPhone using Tapatalk Quote
SlowMoe Posted August 15, 2017 Author Report Posted August 15, 2017 And my clutch is stiffer than Ron Jeremy with a belly full of viagraSent from my iPhone using Tapatalk Quote
spurdy Posted August 15, 2017 Report Posted August 15, 2017 And my clutch is stiffer than Ron Jeremy with a belly full of viagraSent from my iPhone using TapatalkThen maybe your friction plates are glazed or your steels are bad. Sent from my iPhone using Tapatalk Quote
SlowMoe Posted August 15, 2017 Author Report Posted August 15, 2017 I think if that were the case Brantley would have caught it during assemblySent from my iPhone using Tapatalk Quote
spurdy Posted August 15, 2017 Report Posted August 15, 2017 I think if that were the case Brantley would have caught it during assemblySent from my iPhone using TapatalkOk, I'll go with your explanation then. Sent from my iPhone using Tapatalk Quote
SlowMoe Posted August 15, 2017 Author Report Posted August 15, 2017 I'm just confused honestly. Isn't there a clutch upgrade that doesn't involve a lock up? Like an extra plate or something?Sent from my iPhone using Tapatalk Quote
ClaudeMachining Posted August 15, 2017 Report Posted August 15, 2017 I'm just confused honestly. Isn't there a clutch upgrade that doesn't involve a lock up? Like an extra plate or something?Sent from my iPhone using TapatalkDriveline offer an upgrated clutch assembly iircEnvoyé de mon SM-N910C en utilisant Tapatalk 1 Quote
Ayesully810 Posted August 15, 2017 Report Posted August 15, 2017 idk why everybody says that your clutch will be harder to pull at higher rpms with a lockup. My clutch pull doesn't change at all through out the RPM range with my dl lock up. anyone care to explain? I don't have a pro mod tranny but I do have the shift pro arm and modded shift star. I run 6 heavy springs with my FAST clutch in a chariot basket Quote
spurdy Posted August 15, 2017 Report Posted August 15, 2017 idk why everybody says that your clutch will be harder to pull at higher rpms with a lockup. My clutch pull doesn't change at all through out the RPM range with my dl lock up. anyone care to explain? I don't have a pro mod tranny but I do have the shift pro arm and modded shift star. I run 6 heavy springs with my FAST clutch in a chariot basketI don't notice a difference. If you think about it, the lockup applies pressure to your plates in addition to the spring tension. When you pull the clutch in you press the clutch shaft against the pressure plate and have to force the levers at the same time. The levers are rotating faster at high RPMs and thus providing more leverage. I rarely use the clutch while riding though. Only starting and stopping. Sent from my iPhone using Tapatalk 1 Quote
spurdy Posted August 15, 2017 Report Posted August 15, 2017 I'm just confused honestly. Isn't there a clutch upgrade that doesn't involve a lock up? Like an extra plate or something? Sent from my iPhone using TapatalkYou don't need an 8 plate clutch. But I'll cut your pressure plate and boss if you want to run one. Sent from my iPhone using Tapatalk 1 Quote
SlowMoe Posted August 15, 2017 Author Report Posted August 15, 2017 You don't need an 8 plate clutch. But I'll cut your pressure plate and boss if you want to run one. Sent from my iPhone using TapatalkI don't know what I need. I just don't think my clutch should be slipping at my power level if my clutch is good. I think I'm just gonna order new plates and the lock up from driveline. I think that will give me peace of mindSent from my iPhone using Tapatalk Quote
special06shee Posted August 15, 2017 Report Posted August 15, 2017 You dont need a lockup. Get a new decent clutch kit and some heavier springs. I had 421 cubs with stock clutch setup that made in the low to mid 90 hp range. Call cameron up and get his clutch kit. Ive had good luck with them. 1 Quote
