Nick.H Posted August 1, 2017 Report Posted August 1, 2017 I'm sure there's a million other threads about this, but I bought a 1993 banshee yesterday. Has a pro design cooling head, fmf pipes, k&n kit. Rode it twice, parked it, came out 20 minutes later and it pissed out all the oil. Looks like it's coming from near the front sprocket. I know if it's the seal behind there, I have to split the case to fix it. My questions are: 1: is there a fix without splitting the case? 2: if not, how much am I likely to spend at the shop? Don't have time or tools to get it done myself right now. Thanks, Nick Quote
hicksons Posted August 1, 2017 Report Posted August 1, 2017 There wasn't chain slab and cracked the case rite? Sent from my iPhone using Tapatalk Quote
Nick.H Posted August 1, 2017 Author Report Posted August 1, 2017 (edited) 7 minutes ago, hicksons said: There wasn't chain slab and cracked the case rite? Sent from my iPhone using Tapatalk Nothing unusual I can see. I'm not exactly familiar with these terms yet. I've only ever worked on cars specifically SBC's. There's a pool of oil under the chain on the frame no the case is not cracked that I can see. Looks fine Edited August 1, 2017 by Nick.H Quote
hicksons Posted August 1, 2017 Report Posted August 1, 2017 I would take off the chain and sprocket clean it all up and see because you don't want to get that work done and it be a hairline crack in the case my Brotha Sent from my iPhone using Tapatalk Quote
ginger Posted August 1, 2017 Report Posted August 1, 2017 Is it trans oil, or is it fuel? If the carbs overflow there is a drain in the middle of the cases Quote
hoppedupandcutdown Posted August 1, 2017 Report Posted August 1, 2017 you don't have to split the case to replace the seal behind the sprocket. also look at the shift shaft seal below it, It can be replaced from the outside too Quote
Nick.H Posted August 1, 2017 Author Report Posted August 1, 2017 7 minutes ago, ginger said: Is it trans oil, or is it fuel? If the carbs overflow there is a drain in the middle of the cases Trans oil. The case is empty now Quote
Nick.H Posted August 1, 2017 Author Report Posted August 1, 2017 6 minutes ago, hoppedupandcutdown said: you don't have to split the case to replace the seal behind the sprocket. also look at the shift shaft seal below it, It can be replaced from the outside too Would that seal failing cause me to lose all the oil in a matter of 20-40 minutes? Or does that sound worse? Quote
hoppedupandcutdown Posted August 1, 2017 Report Posted August 1, 2017 If it fell out, yes. If it did, check that your case vent is clear. Quote
Nick.H Posted August 1, 2017 Author Report Posted August 1, 2017 What exactly would that seal be called? Sorry major n00b here Quote
hoppedupandcutdown Posted August 1, 2017 Report Posted August 1, 2017 There are 5 possible things to leak in that side of the case 1 -shift shaft seal 2 -Trans output (countershaft) seal 3 -neutral switch o-ring 4 -shift fork bar plugs (2 of those) Degrease, clean, dry and inspect. Quote
Nick.H Posted August 1, 2017 Author Report Posted August 1, 2017 Thanks, and which was the one you were referring to?{the one(s) doable from the outside} Or at least your best guess. Quote
hoppedupandcutdown Posted August 1, 2017 Report Posted August 1, 2017 They are all doable from the outside. IIRC the shift shaft seal is the lowest one, it would dump the most oil. A quart and a half leaves an awful large puddle. Quote
Nick.H Posted August 1, 2017 Author Report Posted August 1, 2017 Thanks. I'll be getting some work done on it tomorrow and I'll post updates Quote
ginger Posted August 1, 2017 Report Posted August 1, 2017 i have had the shift shaft seal fail on an older motor. Quote
