Rapture Posted June 11, 2017 Report Posted June 11, 2017 I was rinding for about an hour with no problems. Held it wide open for about 30 seconds and my pipes went really gold with a blue spot. Is my main jet not quite dialled in or did they just get way to hot? After Before Comparison after i cleaned up the left side Quote
trickedcarbine Posted June 11, 2017 Report Posted June 11, 2017 Typically it's from excessive heat. However, I've never seen them blue beyond the first foot. Definitely check jetting. Quote
Rapture Posted June 11, 2017 Author Report Posted June 11, 2017 1 hour ago, trickedcarbine said: Typically it's from excessive heat. However, I've never seen them blue beyond the first foot. Definitely check jetting. I'm running 320 mains with DMC 916 pipes and a K&N filer. 141 feet elevation, 21 °C . I don't think im lean... the plugs have always been pretty dark/oily. Quote
trickedcarbine Posted June 12, 2017 Report Posted June 12, 2017 Are they chrome for sure not nickle? 1 Quote
rjdgriff Posted June 12, 2017 Report Posted June 12, 2017 Water pump working?Giving away "TSS" for FREE!!! 1 Quote
Nightmare Posted June 12, 2017 Report Posted June 12, 2017 Looks like nickle plate to me.Sent from my LG-H830 using Tapatalk Quote
rjdgriff Posted June 12, 2017 Report Posted June 12, 2017 Were they brand new pipes?Giving away "TSS" for FREE!!! Quote
Rapture Posted June 12, 2017 Author Report Posted June 12, 2017 16 hours ago, trickedcarbine said: Are they chrome for sure not nickle? The DMC paperwork that came with them says they are chrome plated. Quote
Rapture Posted June 12, 2017 Author Report Posted June 12, 2017 2 hours ago, rjdgriff said: Were they brand new pipes? Giving away "TSS" for FREE!!! Yeah brand new pipes. Holding it open for 10-15 seconds is usually ok it's just when its more than that they go gold. Quote
rjdgriff Posted June 12, 2017 Report Posted June 12, 2017 Yeah brand new pipes. Holding it open for 10-15 seconds is usually ok it's just when its more than that they go gold.Return them as defective Giving away "TSS" for FREE!!! Quote
Rapture Posted June 12, 2017 Author Report Posted June 12, 2017 15 hours ago, rjdgriff said: Water pump working? Giving away "TSS" for FREE!!! Is there a easy way to check this without pulling cases off? Quote
Rapture Posted June 12, 2017 Author Report Posted June 12, 2017 Might be worth mentioning as well that after i held it open, i went half throttle for a second or two, then back to open and it started bogging. Cleared after a few seconds. Quote
JUSTWANNARACE Posted June 13, 2017 Report Posted June 13, 2017 Are your slides opening all they way? If not it will run on the needle and not pull into the main circuit causing a lean condition at wide open throttle. Just something to check.. Quote
