I have a 2001 banshee.
First and second shift easy but third through sixth I'm having to use all my force to get it to shift up and it's hard going into neutral. Just curios on. What you guys think the problem could be
Have cool head 19cc domes
Weisco pro lite pistons
Hot rod crank
Boyseen rad valves
Boss intake
F.A.S.T HD fly wheel
CT in frame drag pipes
Adjustable timing plate set at +4
Pingle dual flow
34mm pjs
K&N filter with aluminum intake
If you take the clutch basket out you will see grooves made by the clutch plate teeth. Go get a good file and square these back up or smooth them out. On the other clutch piece it may also have grooveing in it and you will need a good file to get in there and take those out. It will take some time and it makes a difference imo. Or buy a new anodized basket that helps prevent that from happening. The shift drum rides on one bearing on right side. The left side doesn't have one. I installed the closest size roller bearing to fit that and turned the drum in lathe to fit the bearing. Than I installed a couple bearings for the shift shaft to ride on as it originally has bushing. Pro shift mod helps and adjustment is good...
