davidpitsul Posted May 3, 2017 Report Posted May 3, 2017 I am looking for 22x11-8 12-14 Paddle Extremes preferably 74-76 RO. Stags are ok. PayPal ready! Sent from my iPhone using Tapatalk Quote
J-Madd Posted May 4, 2017 Report Posted May 4, 2017 22x11x8 is gonna be 72" roll out. You want a 24" tire if you want 76" roll out. Sent from my STV100-1 using Tapatalk Quote
JTmachining Posted May 5, 2017 Report Posted May 5, 2017 22x11x8 is gonna be 72" roll out. You want a 24" tire if you want 76" roll out. Sent from my STV100-1 using Tapatalk J madd you are not up to speed on paddles. There is tire carcass size and tire RO. Two different things Quote
J-Madd Posted May 5, 2017 Report Posted May 5, 2017 J madd you are not up to speed on paddles. There is tire carcass size and tire RO. Two different thingsHow do you make a 22" tire 76" RO? If you're adding longer paddles then whatever but the tire carcass will be the same as a normal 72" RO extreme. If I'm wrong on this I've been wrong on it for 10 years, and I'm ok with that. Sent from my STV100-1 using Tapatalk 1 Quote
JTmachining Posted May 5, 2017 Report Posted May 5, 2017 J madd you are not up to speed on paddles. There is tire carcass size and tire RO. Two different things How do you make a 22" tire 76" RO? If you're adding longer paddles then whatever but the tire carcass will be the same as a normal 72" RO extreme. If I'm wrong on this I've been wrong on it for 10 years, and I'm ok with that. Sent from my STV100-1 using Tapatalk I said carcass. 22x11x8 tires are high 60s RO to 76 ish RO. No one includes paddle height in RO number unless they have no clues. 10 years? Lol Quote
J-Madd Posted May 5, 2017 Report Posted May 5, 2017 I said carcass. 22x11x8 tires are high 60s RO to 76 ish RO. No one includes paddle height in RO number unless they have no clues. 10 years? LolThen what the fuck does the 22" mean if it doesn't indicate the carcass size. 22" diameter is about 70" around. If adding a ripper to that makes it 76" then ok. But that tire in an extreme is 72" all day long. Pretty sure this OP is not looking for a ripper. Unless you have some odd wheel size. Sent from my STV100-1 using Tapatalk Quote
JTmachining Posted May 5, 2017 Report Posted May 5, 2017 Then what the fuck does the 22" mean if it doesn't indicate the carcass size. 22" diameter is about 70" around. If adding a ripper to that makes it 76" then ok. But that tire in an extreme is 72" all day long. Pretty sure this OP is not looking for a ripper. Unless you have some odd wheel size. Sent from my STV100-1 using Tapatalk I'll make it simple for you. Go look at different tire manufactures for tires in one size. In that same size there's diff ROs. It's not rocket science just facts. I also said peeps with no clues include paddles in RO measurement Quote
J-Madd Posted May 5, 2017 Report Posted May 5, 2017 I'll make it simple for you. Go look at different tire manufactures for tires in one size. In that same size there's diff ROs. It's not rocket science just facts. I also said peeps with no clues include paddles in RO measurementA tire in a different size will vary a tiny amount from manufacturer to manufacturer in roll out. Not that much. I'll stay clueless. Sent from my STV100-1 using Tapatalk Quote
JTmachining Posted May 5, 2017 Report Posted May 5, 2017 what the fuck Sent from my STV100-1 using Tapatalk Yes WTF is right. I thought you were in the know Quote
guns4children Posted May 5, 2017 Report Posted May 5, 2017 We need a grudge match! Make it happen!! Quote
special06shee Posted May 5, 2017 Report Posted May 5, 2017 (edited) Jt, are you trolling? Because what your saying is completely wrong compared to what SKAT TRAK will tell you and common sense. Edited May 5, 2017 by special06shee Quote
guns4children Posted May 5, 2017 Report Posted May 5, 2017 t Jt, are you trolling? Because what your saying is completely wrong compared to what SKAT TRAK will tell you and common sense. It's TSS you obviously are not in the know. 1 Quote
special06shee Posted May 5, 2017 Report Posted May 5, 2017 It's TSS you obviously are not in the know.lol. There is LOTS i dont know. I wasent question tabata really, i was just always told RO was measurements with paddles included. Quote
JTmachining Posted May 5, 2017 Report Posted May 5, 2017 We need a grudge match! Make it happen!!J madd doesn't race Quote
lastnline75 Posted May 5, 2017 Report Posted May 5, 2017 J madd doesn't raceHe might...if banshees came with automatic trannys... 1 Quote
