Brandonb028 Posted April 30, 2017 Report Posted April 30, 2017 Basically just put a new float jet in it and that's all. Was leaking gas out the over flow so float was sticking more less. Won't kick and start. Just pops and backfires and gets really hot when pull starting it. Any ideas? 98 banshee. Motor is basically stock from what I know about it has fmf pipes and slip ons and jetted. Ran fine until it started leaking gas. Quote
hoppedupandcutdown Posted April 30, 2017 Report Posted April 30, 2017 Is that black hose in between the carbs? Quote
Brandonb028 Posted April 30, 2017 Author Report Posted April 30, 2017 Just put one on and still won't kick start Quote
hoppedupandcutdown Posted April 30, 2017 Report Posted April 30, 2017 Bowl with "BB" at red arrow in pic on the left carb? 1 Quote
Brandonb028 Posted April 30, 2017 Author Report Posted April 30, 2017 Yep I kept them separate when I re did them Quote
hoppedupandcutdown Posted April 30, 2017 Report Posted April 30, 2017 Slides in the correct carbs? Didn't change any main or pilot jets from a rebuild kit did you? Quote
Brandonb028 Posted April 30, 2017 Author Report Posted April 30, 2017 Yep marked the slides also. Left the main and pilots the same since the rebuild kit came with stock ones since these ones where not Quote
Brandonb028 Posted April 30, 2017 Author Report Posted April 30, 2017 Just for kicks and giggles how do u know what slide goes on what side Quote
hoppedupandcutdown Posted April 30, 2017 Report Posted April 30, 2017 All 3 of TORS plugs plugged in? Or non at all, can't be any other combination Quote
hoppedupandcutdown Posted April 30, 2017 Report Posted April 30, 2017 If you can see the dots in the window at WOT you are good or Quote
Brandonb028 Posted April 30, 2017 Author Report Posted April 30, 2017 All three? Thought there was only 2. I only unplugged 2 so if there if a third it should still be connected. Quote
hoppedupandcutdown Posted April 30, 2017 Report Posted April 30, 2017 AH HA! unplug the 3 wire brain box under the left side of the tank Quote
Brandonb028 Posted April 30, 2017 Author Report Posted April 30, 2017 (edited) Pic won't upload. What does this do unplugging it? Unplug the tores also? Edited April 30, 2017 by Brandonb028 Quote
