dag8501 Posted February 27, 2017 Report Posted February 27, 2017 I have a 2 piece wicked intake that has several leaks where the intake splits in half. I have tired to grease the large o-ring and even put yamabond on the o-ring and mating surface with no luck. Should I just replace the o-ring even though it looks fine? If so where can I purchase a new o-ring. Any suggestions would be appreciated. Quote
hp2000 Posted February 27, 2017 Report Posted February 27, 2017 I'm not a fan of billet intakes. I run UPP manifolds and never have problems. Sent from my iPhone using Tapatalk Quote
Nightmare Posted February 27, 2017 Report Posted February 27, 2017 Reinstall a new oring with some vasoline and should be good. I had the same problem with the same intakes. Sent from my LG-H830 using Tapatalk Quote
Canadianshee Posted February 28, 2017 Report Posted February 28, 2017 I use a o-ring lube called Molly Coat 55 (this is is in Canada though eh ). Its used in aviation on o-rings and seals. Its also used in high end paintball markers. Its a lube that causes the o-ring to swell back to it original size but maintain its integrity and lubricates. You can get it at specialized shops in Canada. Its expensive stuff to get the name brand. I will take a look through my paint ball stuff to find the name of the paintball o-ring lube. Same stuff different name and smaller size (save you money). Quote
sleeper06 Posted February 28, 2017 Report Posted February 28, 2017 The first thing you need to do is pull it apart and ruff up entire mating surfaces with Emory cloth. Then clean all areas with ascetone till it passes white rag test clean. Get threebond 1211 and apply it everywhere including oring grooves. Tighten it up and allow 24hrs drying time. Problem solved. I've done 50 or more this way with zero leaks. Ruffing up the surfaces is key. I've also heated the manifold with heat gun before applying 1211 to open pores of aluminum but I've also done it with no heat. Remember if your working in a cold environment everything takes longer to dry and just about any assembly process sucks Quote
trickedcarbine Posted February 28, 2017 Report Posted February 28, 2017 Lap the pieces on a piece of glass or granite with the emery or 600 grit. Quote
