Medicshee350 Posted February 6, 2017 Report Posted February 6, 2017 If I advance my timing 4 degrees will I need to rejet, or will it be fine? Quote
STRIBZ Posted February 6, 2017 Report Posted February 6, 2017 should be fine, do a plug chop to make sure. Quote
blowit Posted February 9, 2017 Report Posted February 9, 2017 Advancing timing does not require rejetting, however, if jetting is borderline lean, this can lead to detonation issues. Make sure your jetting is dialed in, and as recommended, check plugs after timing change, especially the ground strap for indications of heat. However, 4* is a pretty standard and safe value for pump fuel engines and usually works without issue. Brandon Mull Engineering Quote
