Ducman Posted January 17, 2017 Report Posted January 17, 2017 Its been 2 years since my banshee was running. I don't know why I waited so long to fix it, but it was mostly because I didn't have the funds to take it to a shop or send the motor off and have it fixed. I had a piece of piston come off the right piston, caused no damage on that side, went to the left side through the transfer ports and put a bunch of dings in the dome and piston before it exited the exhaust on the left side. Surprisingly the motor was still running ok after that ocured although definitely not 100%. I was worried that the cylinders would be damaged too but amazingly their was just some scuffing on the piston and the cylinders were perfect, not a scratch whatsoever. Anyway, it took about 5 hours to remove cylinders, install new pistons, put it back together, measure squish .044", and she fired up on the second kick and ran perfect. The only difficulty I had was getting the old wrist pins out so I could remove the pistons, but with a few tender love taps they came out. Now the dune fever is starting to kick in. Quote
sheerider11 Posted January 17, 2017 Report Posted January 17, 2017 I had a piece of piston come off the right piston, caused no damage on that side, went to the left side through the transfer ports and put a bunch of dings in the dome and piston before it exited the exhaust on the left side. What?! Quote
Mr.banshee Posted January 17, 2017 Report Posted January 17, 2017 Magic.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk Quote
trickedcarbine Posted January 17, 2017 Report Posted January 17, 2017 Umm, if in fact what you are describing is damage on an opposite side of a damaged piston, you need to check the crank. Parts from the right side can't physically feed to the opposite side if everything is in the condition it needs to be. That means debris had to go through two bearings.... Or something on that other side let go that you didn't notice. 1 Quote
sleeper06 Posted January 18, 2017 Report Posted January 18, 2017 He will notice soon enough if there's an issue. Quote
Ducman Posted January 18, 2017 Author Report Posted January 18, 2017 He will notice soon enough if there's an issue. I couldnt find or suck up with the shop vac any evidence of the piece of piston out of the crank area. The crank still felt very smooth and you could rotate it easily by pushing on the rods. Its been running perfect for a couple of hours now. I knew there was some risk in just doing the top end but so far its working out. Quote
bigweav81 Posted January 18, 2017 Report Posted January 18, 2017 Wait til it's spinning enough to pick up whatever is in there. Who knows maybe not. Sent from my SM-S820L using Tapatalk Quote
RagunCajun Posted January 19, 2017 Report Posted January 19, 2017 I would of split the cases and went through it. 1 Quote
