I've got a DC stator I wanna send to another member, but I wanna make sure it at least a tests good before I send it out. Should I be ohm testing it the same way you would a stock stator?
ask Gary tabor
  • 3 weeks later...
Not sure if you got your question answered but there is no such thing as a DC stator.  All stators will produce AC and will test out the same in regards to meter testing.  The only difference in ones being used for DC conversions is the ground wire for the lighting is not grounded to the mount plate, but rather carried back to a rectifier box.
Your lighting side test would just be the yellow and black wires IIRC.
Brandon
Mull Engineering
  • Like 1
