i think u have t pull off the whole side case. On the bac side is a c-clip. Im not sure, but i think thats what it was last time i had mine apart. By the way, how much does a new impeller cost? Peace out.
The new impeller is about 30 on Ebay. You will need to remove the circlip on the inner side before it will come out. Also, if my memory is working correctly, there is a small bearing and seal that you should replace while you are in there. Do it right the first time.
www.bluetraxx.com go there and look in the tech tips. There are step by step instructions on how to remove it
