I have an issue with my banshee revving up when under load seems to be ignition related . Mostly does it in first at wot and 3/4 of the Rev range. It bogs until you shift. Does great when in higher gears just in lower gears . Jetting is good I have changed the plugs they have good color just changed caps on wires .
What size domes? Have you checked your squish? If you have trinity domes, you might need to get yourself some new domes. You might not need 110 octane. Are your carbs Airstrikers? What size pilot do you have? Check and see if your pv's open all the way up. You might need to cut them to match the roof of the exhaust port when they are fully open.
Sent from my VS990 using Tapatalk
It idles great and cleans up when you get on it plugs look great. Jetting is good cranks on first kick can be intermittent at times dosent do it if you roll into throttle. It does not sounds fat or lean out .
