Cnelson47 Posted July 21, 2016 Author Report Posted July 21, 2016 Is it running on both cylinders? Like I said before, I've seen this when the wrong pin height pistons are used. Do you still have the piston box or receipt? Did you hone the cylinders? This is stock stroke, stock rod? 65mm wiseco pistons. Cylinders were honed and the crank is a standard trued and welded crank from vitos. Quote
Cnelson47 Posted July 21, 2016 Author Report Posted July 21, 2016 65mm wiseco pistons. Cylinders were honed and the crank is a standard trued and welded crank from vitos. crank is 54mm stroke 110 rod Quote
J-Madd Posted July 21, 2016 Report Posted July 21, 2016 This might not be your problem but "wiseco 65 mm pistons" doesn't help answer my question. You might have long rod pistons in it by accident. Do you know what I mean by this? What are the numbers on top of the pistons or on the box? Quote
J-Madd Posted July 21, 2016 Report Posted July 21, 2016 513M06500 is the piston you need. If it says 795M06500 it is for long rod. 1 Quote
sheerider11 Posted July 21, 2016 Report Posted July 21, 2016 513M06500 is the piston you need. If it says 795M06500 it is for long rod.I thought the skirts hit the Web if you do that Quote
J-Madd Posted July 21, 2016 Report Posted July 21, 2016 Hmmmm. I don't know. And I don't exactly remember the specs on the motor I worked on that had the wrong pistons. I do know it sounded exactly like OPs though. Quote
sheerider11 Posted July 21, 2016 Report Posted July 21, 2016 Hmmmm. I don't know. And I don't exactly remember the specs on the motor I worked on that had the wrong pistons. I do know it sounded exactly like OPs though.I remember I put some pistons on a crank. Possibly a 4 mil 110 rid and it did or some configuration. Quote
Cnelson47 Posted July 21, 2016 Author Report Posted July 21, 2016 513M06500 is the piston you need. If it says 795M06500 it is for long rod. I believe you have just solved my problem. My pistons say 795m06500 Quote
J-Madd Posted July 21, 2016 Report Posted July 21, 2016 I believe you have just solved my problem. My pistons say 795m06500Good deal. If you got the whole kit from Vitos it is their screw up. They should know better. You may want to run a hone through the cylinders before you put the new correct pistons in. Quote
Cnelson47 Posted August 1, 2016 Author Report Posted August 1, 2016 UPDATE Received the correct pistons and put them in. Banshee runs great now. Thank you to everyone who put their in. I really appreciate all of the help! Quote
bigweav81 Posted August 1, 2016 Report Posted August 1, 2016 J-Madd is who to thank! You could've been trouble shooting your ass off still. Glad it's sorted out. Sent from my SM-S820L using Tapatalk Quote
