So ive started a "build". Right now i've got stock carbs, k&n pods, v-force 4's, no spacers, and CPI pipes.
I went through the carbs.
I bought the bike with PSI pipes, air box in place with a foam filter.
The main jet was at a 220, pilot a 25...
I'm at 4800', in UT.
I threw in a 280, cause thats what I had... kept the pilot the same... Took it for a quick putt, and the bike is stuggling.
Question is... where is a good place to start? Is 280 too big? 25 too small?
Thanks for the help guys!
With the mods that were on it and stock jets, I'm surprised it even ran without melting a hole in a piston. Have you verified that there is even life left in the motor with a quick compression test?
With your mods, you'll wanna be at least 27.5 pilot, needle second clip from the bottom, 290ish main.
