Picked up this banshee for $500 last night, guy I got it from got it in a package deal and didn't want anything to do with it, anywho, quads pretty complete, I can tell it's been sitting a while, has bad gas, wiring is a bit iffy, worst of all no spark. Engine does have 125psi in each cylinder though, so that's a good starting point.
Anyway I took off the tank and plastics to look over the wiring, under the tank there is a 3 way splice being bridged to another wire by wire nuts, any idea what this could be for? Also all key ignition wires were cut, so I put the 2 wires together however that did not give me spark, so there's still a problem somewhere. I've never trouble shot wiring on an atv before, so could someone give me a hand on where to start? What to look for? I would assume start at the stator then cdi then coil, but I do not know how to test these pieces.
Here are some pictures:
Bike looks great for $500 hundo.
Wiring is fairly basic. Just don't over think it. It will drive you crazy. Keep up posted.
BTW
Welcome to BansheeHQ :)
But seriously find corey Kennedy (kompulsive concepts) and buy a whole brand new harness. Literally the cheapest easiest investment into your time and frustration.
Eliminate that cluster fuck you have there.
Save yourself the headache.
  • Like 2
He will also sell u just the weatherpack connectors if your confident in wiring. If not just order a harness from him, if that's out in the open I can only imagine what's hiding
So I ohms tested my stator today, and the ignition coil was at about 25.5 ohms (when max is 20.5), pick up coil was within spec, and lightning coil was at 9.5-10 ohms (when max is 0.38)
Could this cause my no spark condition?
Took off the flywheel cover and noticed it was kind of rusty, is this an issue or normal for a quad of this year?
Edited by DieselJoe
I agree with getting a new wiring harness.  Looking at your pics it seems you have a short considering the burn marks.  I picked up a brand new harness from jds customs and it's a real nice piece.  I'd replace the stator and CDI now with OEM pieces too.  Check the for sale section or put up a wtb ad.  Good luck and report back once you get it fixed.
Did u pick this bashee up in illinois?
Lol man i was gonna buy that lol literaly got on it a copuple hours befor me, but im right here in lockport, If u need help let me know. U got a sweet dea man
Edited by Yamahafan#1
