  • 2 weeks later...
on single cylindar machines all you have to do is wrap a wire around the spark plug tip, then push on your cap. the other wire goes to any ground on the frame. the hot wire then goes to the tachometer(any tachometer). thats all thats needed, this should still apply for a banshee just use one spark plug, both plugs will be doing the same thing.
