Heavyd442 Posted May 15, 2016 Report Posted May 15, 2016 Hello, Need some advice, toasted my crankshaft lower rod bearing last trip out. Changing my setup, and would like some advice. Here is what I had. 4 mill long rod Stock bore, aggressive port (drag) 35 mm mikuni carbs, billet intakes with boost bottle. CPI in frames Cool head, 19 domes Ran 50%110 race fuel and 50% pump premium. 4 inch extended swingarm. Here is where I am going. New 4 mil long rod crankshaft Trued and welded by redline, updated bearings. Pro mod trans (redline) 421 serval with mild dune port Driveline performance 22 domes Driveline clutch Hinson complete set up. Pro design billet impeller I want to run pump premium, and just play in the dunes mostly. I drag race once in a while, but nothing serious. Should I switch to 33pwk's instead of 35 's I have billet intakes now with a boost bottle, should I switch to a Mattoon or other one piece billet intake with the built in crossover ? Do those work ok ? Fuel lines are tight with the boost bottle and cpi's. I just want it to run good, and have some good power, but be dependable. Tired of f'ing with the four strokes. Any input, advice, suggestions ( other than to go F myself) would be appreciated. When the build is done, i will also ask for jetting help. Thanks D Sent from my iPhone using Tapatalk Quote
wayne_smith97 Posted May 15, 2016 Report Posted May 15, 2016 Switch to upp intakes and forget about the boost bottle. Quote
Heavyd442 Posted May 15, 2016 Author Report Posted May 15, 2016 Switch to upp intakes and forget about the boost bottle. Ok, I looked at those I think, they are all rubber, but still take a crossover tube correct ? Thanks D Quote
ClaudeMachining Posted May 15, 2016 Report Posted May 15, 2016 Ditch the cross over tube while you're at it. Buy non cross over intake. Envoyé de mon GT-P5113 en utilisant Tapatalk 1 Quote
trickedcarbine Posted May 15, 2016 Report Posted May 15, 2016 Ditch the boost bottle and get a manifold/s with out a crossover. I think with a serval 22cc domes is cutting it close for premium pump if you're on 91 octane. 93 is probably ok if you're not adding timing. Run 35's if you like to get wide open a lot. If you're in constant tight twisty stuff, you may find that the 33's will feel a touch more responsive but won't charge up top like 35's will. Quote
Heavyd442 Posted May 15, 2016 Author Report Posted May 15, 2016 Ditch the boost bottle and get a manifold/s with out a crossover. I think with a serval 22cc domes is cutting it close for premium pump if you're on 91 octane. 93 is probably ok if you're not adding timing. Run 35's if you like to get wide open a lot. If you're in constant tight twisty stuff, you may find that the 33's will feel a touch more responsive but won't charge up top like 35's will. Thanks Quote
