Joeschwab Posted April 12, 2016 Report Posted April 12, 2016 I did a full rebuild on my banshee it is running good it runs great at idle but when I hold the throttle at about 1/2 the left cylinder stops running when I give a quick Rev the cylinder fires great but not when I hold it open Quote
Oldskool83 Posted April 12, 2016 Report Posted April 12, 2016 Coil is shitting the bed. It sounds electrical, OR you main jet has something clogging up in your getting. If your fuel is more then 2 weeks old it better have stabilizer in it for sure. Quote
Joeschwab Posted April 12, 2016 Author Report Posted April 12, 2016 Carbs have been cleand and if the coil was bad and I switch the wires wouldn't it change cylinders and if it was Gas wouldn't that effect both cylinders Quote
Joeschwab Posted April 12, 2016 Author Report Posted April 12, 2016 And what octane should I be running with 16 cc domes Quote
sheerider11 Posted April 12, 2016 Report Posted April 12, 2016 And what octane should I be running with 16 cc domesWhat is your compression. Unless your way up in the mountains, you need race fuel. Quote
Joeschwab Posted April 12, 2016 Author Report Posted April 12, 2016 Compression is at 150 I also run 6 degrees timing that's why I was running 110 Quote
Joeschwab Posted April 12, 2016 Author Report Posted April 12, 2016 And yes I ride from 5000 feet to 9000 Quote
Larry's Shee Posted April 13, 2016 Report Posted April 13, 2016 Did you remove emulsion tube when you cleaned carbs? Both needles same and same clip? Quote
stunter01 Posted April 13, 2016 Report Posted April 13, 2016 Did you change the crank or had new condors fit. Had the same problem years ago and the crank was not pressed true . Quote
