echatman Posted March 20, 2016 Report Posted March 20, 2016 BRap where are you jetted? I have the same setup and having some issues. Sent from my iPhone using Tapatalk Quote
echatman Posted March 21, 2016 Report Posted March 21, 2016 As far as fitment goes, i ground the bottom portion of the tabs off the airbox to be able to move it into place easier. Just so that the tabs rest on top of the frame and you don't have to push forward and into place. I put the boot on the carb and slid the carb into the airbox then bolted the boot to the intake. Mine sits flush after that, then i bolted the box down. Sent from my iPhone using Tapatalk Quote
jbooker82 Posted March 22, 2016 Report Posted March 22, 2016 Turn the clamp so the screw isn't down in the bottom. That way your not trying to pinch the clamp when flexing the carb / air box down. Quote
