01sheenoby Posted March 4, 2016 Report Posted March 4, 2016 Buddy is doing a rebuild. He baught new stock cylinders. Installed the studs for new cool head. Tried placing head down on studs and they don't line up with the holes. Any advice on how to Correct them problem? Quote
01sheenoby Posted March 4, 2016 Author Report Posted March 4, 2016 This is a pro design cool head by the way. Thanks guys. Quote
01sheenoby Posted March 4, 2016 Author Report Posted March 4, 2016 I believe the heads were baught online. I'm going to guess eBay. Quote
01sheenoby Posted March 4, 2016 Author Report Posted March 4, 2016 I believe the cylinders were baught online. I'm going to guess eBay. Quote
Bennett131 Posted March 4, 2016 Report Posted March 4, 2016 We're the cylinders tightened down on the cases or just laying on a table so to speak? Quote
01sheenoby Posted March 4, 2016 Author Report Posted March 4, 2016 Yes cylinders were tightened. But I already see where you're going with this. Should loosen them up correct? But would that destroy base gasket? Quote
Bennett131 Posted March 4, 2016 Report Posted March 4, 2016 You need to losen them up. Personally I would get a new base gasket because I'm picky about those things. You are probably fine though. Quote
Bennett131 Posted March 4, 2016 Report Posted March 4, 2016 As long as you do a leak down test afterwards. If it holds wgaf. Quote
Surfrjag Posted March 5, 2016 Report Posted March 5, 2016 some aftermarket nich ebay cyls wont line up to well... so I hear Quote
bigweav81 Posted March 5, 2016 Report Posted March 5, 2016 ^^^^^^^^ look into that. Those new stock cylinders from eBay could be niche. sent from yo mammy house. Quote
Keno Posted March 5, 2016 Report Posted March 5, 2016 I'll just leave this here http://bansheehq.com/forums/index.php?/topic/185616-need-help-with-head-alignment/ Quote
