NRA Posted February 20, 2016 Report Posted February 20, 2016 Hello all. I am new here and have done much researc. I just picked up a 06 very clean. Stock motor, only mods are pro circuit platinum exhaust, boost bottle, pro design intake w kn, tors delete. I'm having an issue w a low end bog during initial clutch release. Have to really get her singing in order to take off or she bogs hard and wants to stall. I suspected the carbs needed to be cleaned and possibly a clogged pilot, so I ran a compression check and both cyl were 125. Then proceeded to clean and inspect carbs. Did not see anything in the jets or carbs that was like "ahhh here we go" .... Mains are 280 and pilots are 25. Put her back together to same results. Any help would be much appreciated, thanks in advance Quote
sheerider11 Posted February 20, 2016 Report Posted February 20, 2016 Bring the air screws all the way in and see if it helps. If it does then get a27.5 pilot and bring the screws 2.5 out. See how it reacts. 2 Quote
NRA Posted February 20, 2016 Author Report Posted February 20, 2016 Thanks for your reply sheerider. Just picked this machine up, it was in storage for the past three years and has little use. The tors delete was installed by a Yamaha dealer and has the added idle screw kit installed. Does this make any difference on your instructions? Quote
hoppedupandcutdown Posted February 20, 2016 Report Posted February 20, 2016 Thanks for your reply sheerider. Just picked this machine up, it was in storage for the past three years and has little use. The tors delete was installed by a Yamaha dealer and has the added idle screw kit installed. Does this make any difference on your instructions? No, and just to be clear - he said air screws, not idle screws. Quote
Sandking Posted February 20, 2016 Report Posted February 20, 2016 No, just do as sheerider instructed. Quote
NRA Posted February 20, 2016 Author Report Posted February 20, 2016 Great, thanks. Will do after work and report back. Quote
NRA Posted February 20, 2016 Author Report Posted February 20, 2016 Turned the air screws in all the way and it helped tremendously. Got home to late to make it to the local shop to grab those jets, but am getting them in the am and will proceed w the 27.5's and 2.5 out. Then report back. Thanks again Quote
NRA Posted February 27, 2016 Author Report Posted February 27, 2016 Finally got my 27.5's installed and air screws started at 2.5. Same results. Moved to 2 then 1.5 with same results. Thinking possible air leak or needle adjustment. Any help would be great. Thanks in advance Quote
Larry's Shee Posted February 27, 2016 Report Posted February 27, 2016 boost bottle, e If that isn't your problem, some day it will be. Quote
NRA Posted February 27, 2016 Author Report Posted February 27, 2016 It has a white bros bottle on it. Are guys just running the regular cross over pipe? I was hoping the jets and pilot air screw would take care of this issue. Thinking the needle may need to come down one clip.... Quote
Larry's Shee Posted February 27, 2016 Report Posted February 27, 2016 I just used some PVC caps that fit the carb boots. Installed with three bond and clamps. It showed some cracking and started leaking about 4yrs later. Quote
NRA Posted February 27, 2016 Author Report Posted February 27, 2016 So I removed the dynojet needles and installed the factory needles in middle clip, seemed to help a lot. Pilot screws ended at 1 turn out. I think the one turn out is due to the winter weather, and it being 30 outside. Quote
