Picked up a bike that squeaked the left piston. Spark plug came loose, due to, Trying to determine why now) rider error or detonation.
Right one looks good. No marks.
Cylinders are being re-nikasiled now.
Is it okay just to get one piston and rebuild?
Or?
Guest XDOVAYA
I would replace both pistons at the same time..but that's just me however i am a specialized mechanic.
Have you figured out why that piston shit the bed?
When he jumped off the bike after it started shutting down on him, the left plug was loose. The guy was a neighbor and he was just in the middle of a plug chop run. He was about to hit the kill switch when it just started getting tight.
Looks like a blown crank seal.....
 id make damn sure to leak down that monster or you just wasted your money......
For sure, I'm not sure why he didn't right after it happened, but he was pretty sure it was due to the one spark plug.
After its all re-assembled i will make sure it passes will no drop in PSI.
Thanks for all your input.
I'll grab a couple pistons and do it right.
Pistons gradually get smaller up the skirt , I start my measurements 3/8-1/2" from skirt bottom and work up keeping it square. I find a dial caliper is the the easiest and most effective, venir caliper is too Inconsistent IMO
