6038fc4e1abd6a81f152eca3ac3ecfdc.jpgbc979978bdbe54e167f1715ef1a0338b.jpg460e711b600349c6092f678e2fef5992.jpg5e6b408a7cd29723fd3c77f2bfc56830.jpg64729b2fe7b4cff1c50fa9051eaca47a.jpg7438e32d10a8314f1dbf1828ac8c34a8.jpg
Can someone i.d these cylinders? The bike they came from was shipped in from Germany. They are .50 over 68mm bore, have been sleeved, and ported. Notice the notches in the reed flange.
Also notice the bridged dual boost port.
Also i should have cleaned the ports they look shotty, but are just dirty. The porting actually looks nice and uniform.
If you have extra time. Throw on a degree wheel for shits, and gigs. Curious what durations are.
sent from yo mammy house.
I need pistons to degree it up. I was hoping someone could help with cylinder i.d so i could order the correct pistons.
Where do you see a bridged ex port? Take a venir caliper and measure the bore, wsm has Pistons and gaskets
I believe he was referring to the bridged boost ports. Have you ever seen that?
  • Like 1
Not the ex port. The boost port. Bore mesaures 69.63mm
might have been a sleeve from some ktm.
nothing in there looks all wacko or nutty.   besides the weirdo crap in the intake flange area.
if you do a top down measurement of the exh and transfer most can do a rod/ stroke combo comparison for piston, dome and cc setup.
  • Like 1
I'll do that when i get to my shop in the morning ^
im thinking someone did the work way back in the day. doing something like that today wouldnt make any sense. ktm been using nikisil since '85 and probly even earlier. plus at that time the stroke was nearly 70mm so the sleeve from that time period would be all wrong. its easy enough to take a blank sleeve and cut the windows any where you want ,which is what im thinking they did
Exhaust port measures from the deck down @ 25.4mm, and the transfers from the deck down are 41.8mm (opening simultaneous)
