snowmobra Posted November 10, 2015 Report Posted November 10, 2015 What's the best way to clean a crack. I got some dirt in it. Thank. Sent from my HTC One_M8 using Tapatalk Quote
Lowroll Posted November 10, 2015 Report Posted November 10, 2015 You posted this yesterday too word for word in a different section Sent from my SM-N910V using Tapatalk Quote
snowmobra Posted November 10, 2015 Author Report Posted November 10, 2015 Yes it out. Low roll I put it in wrong section. Sent from my HTC One_M8 using Tapatalk Quote
snowmobra Posted November 10, 2015 Author Report Posted November 10, 2015 Is it out?Yes it is out. Thanks brother Sent from my HTC One_M8 using Tapatalk Quote
sheerider11 Posted November 10, 2015 Report Posted November 10, 2015 Yes it is out. Thanks brother Sent from my HTC One_M8 using Tapatalk You can try diesel and compressed air. But that only works for the outer bearings. If it's a lot then you can try this and keep dumping clean diesel over it till you can feel the bearings spin smooth. But it's 50/50 at that point. Might work, might not. Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
possum Posted November 10, 2015 Report Posted November 10, 2015 I spray WD all in the bearings and blow it out over and over till I feel its clean. Then pour some mix in the bearings and reload it with oil. Quote
trickedcarbine Posted November 10, 2015 Report Posted November 10, 2015 No access to a parts washer? Quote
snowmobra Posted November 10, 2015 Author Report Posted November 10, 2015 That's man. Sent from my HTC One_M8 using Tapatalk Quote
sleeper06 Posted November 10, 2015 Report Posted November 10, 2015 I use carb clean , then wd , the when I feel all bearing are not dragging I inject 20-50 four stroke oil in there or royal purple assembly oil Quote
