FMF Golden series
FMF powercore 2
Stock carbs with 280 main jets and stock pilots
22" rear tires and front also
Stock airbox with lid
Bored to 64.50mm
Using: 14/41, with this setup ask 7th gear
before used: 15/41, but I think can be better
That's opposite what OP is asking for. Higher rear would add acceleration and lower top end.
OP, you must do a lot of wide open riding. Have you tried 15/41 on that combo? One tooth up front is about the same difference as 3 out back. It would be likely about all the gear you could pull with your set up IMO. Maybe try 15/39, but that and those 22" tires are gonna make it feel flat up top.
  • Like 1
Yeah, this sound to more top speed and this is that I try to find, I try with this gearing thanks
