To much oil = lean condition?
dont snomos use almost no oil at idle and a shitload at full tilt ? that should answer your less is less question. and if less was more then why not 80 or 100:1 ? less is more right ? after all todays oil is so good that just a couple drops will do
im still looking for the triple face palm icon for your first comment. you know the one where you said 16:1 just blows oil out the pipes, sludges the crankcase, fouls plugs and wont let the engine run because it just simply doesnt have enough gas mixed in. hopefully any new guys are smart enough to do their own research and dont believe any of that nonsense. only takes a few minutes and all your 16:1 statments can be proven as bullshit
