replaced my clutch with a gummed up cable because it grabbed at the very very end of my lever travel. so i bought a clutch kit with heavier springs, adjusted it and it was god awful to pull. took off my clutch cable and i couldnt even pull it with my hands it was so tight and replaced it and it is worlds better.
my question is, where should the screw on my lever be when i adjust my clutch. all the way in or about middle i was thinking but its just an assumption.
i have tried finding in older posts but had no luck. if i take my case apart i would just like to do it one more time.
I like it to be in the middle but wherever it has 1/8 slack in cable is where it should be. The arm line up with cases like described in the manual?
after i replaced the cable it was on the left of the arrow on the case. twisted the nut on the lever to line it up, but there is still alot of travel before it grabs. when i did my clutch on my old warrior it grabbed alot sooner so thats what i am comparing it to. different bike so it could be totally wrong though
:shrugani:
