12-o-clock-wheelie Posted May 14, 2015 Report Posted May 14, 2015 Well basically I had no spark and went through the whole electrical system already triple tested everything works problem was shitty ground from ignition coil where it mounts to the frame. I now have about 20 v power between the 2 spark plug leads and bought brand new plugs. Poured a little gas down cylinders to see if she'd turn over a little bit and it did. Put gas tank on hooked up fuel line kicked it over and nothin...took tank off still no spark retested for power still had 20 v power but no spark?? Quote
trickedcarbine Posted May 14, 2015 Report Posted May 14, 2015 Carbs getting fuel? It fired with fuel being put in the cylinder, so I'd suspect the carbs at this point. Clean them, clean the petcock, check choke tube and slides. Quote
12-o-clock-wheelie Posted May 14, 2015 Author Report Posted May 14, 2015 Yes carbs work everything was cleaned and inspected also when I removed gas tank and poured gas down cylinders again it still wouldn't fire or get spark yet it has 20 v power Quote
sheerider1026 Posted May 14, 2015 Report Posted May 14, 2015 I had a brand new plug that was internally shorted. Chased that gremlin for a while Quote
12-o-clock-wheelie Posted May 17, 2015 Author Report Posted May 17, 2015 I'm not saying you guys are wrong but it can't be the plugs? There brand new and it fired once but now it wont. Still 20 v power but no spark. Sooo confused Quote
wayne_smith97 Posted May 17, 2015 Report Posted May 17, 2015 At least try some new plugs. May not be the issue but you won't know til you try. Quote
sheerider1026 Posted May 18, 2015 Report Posted May 18, 2015 Where are you getting 20v? Are you by chance testing the lighting cool of stator? Quote
