OutlawCM85 Posted May 18, 2015 Author Report Posted May 18, 2015 I have 30 pilots and 290 300 mains but haven't tried them yet Sent from my SCH-R530U using Tapatalk Quote
OutlawCM85 Posted May 18, 2015 Author Report Posted May 18, 2015 Oh and by the way thanks for the help! Sent from my SCH-R530U using Tapatalk Quote
fastbanshee8 Posted May 18, 2015 Report Posted May 18, 2015 Stock pipes, or after market pipes? Quote
lowidenfast Posted May 18, 2015 Report Posted May 18, 2015 Yeah, what are your mods? Do you have pipes, reeds, air box, what's your elevation etc.? Sounds like you are running stock jets if I'm not mistaken. If you have any mods, I'd say you are way lean. Makes sense that choking it gets it to crank too. If the bike runs better with the choke on, I'd think you are lean 1 Quote
OutlawCM85 Posted May 20, 2015 Author Report Posted May 20, 2015 Ok it has a dmc exhaust k &n air filter with stock airbox and lid the reeds are aftermarket I am pretty sure I just dont know what brand . They are like a orange color and look like kinda plastic . Elevation is anywhere from 1000 to 1400 above sea level . Again I did a top end rebuild and cleaned the carbs replaced the float needle and seat and main needles in both carbs . Again my main jet is 250 and pilot is 25 . Thanks again guys for the help . I am so close to having the girl back up and running it is killing me . Sent from my SCH-R530U using Tapatalk Quote
98_sheester Posted May 20, 2015 Report Posted May 20, 2015 Id put a 280 main and 27.5 pilot i would think but do a plug chop make sure Quote
OutlawCM85 Posted May 20, 2015 Author Report Posted May 20, 2015 Ok thanks I will try it and let you know what happens Sent from my SCH-R530U using Tapatalk Quote
OutlawCM85 Posted May 21, 2015 Author Report Posted May 21, 2015 Ok I guess im gonna have to order them . I went to tht local morgantown powersports and they give me the wrong ones and said that they was the only ones they had . Also said that they wouldnt give me my money back if I threaded them in . But I found the rite ones on P.J. motorsports .com . So I will give you a update as soon as I get them in . Thanks again for the all the help !! Sent from my SCH-R530U using Tapatalk Quote
OutlawCM85 Posted June 7, 2015 Author Report Posted June 7, 2015 Ok i got the jets put in,280 mains and 30 pilots and now it wont idle at all even with the choke on . I'm still researching but any help will be appreciated ! Sent from my SCH-R530U using Tapatalk Quote
98_sheester Posted June 7, 2015 Report Posted June 7, 2015 Pilot might be giving it too much fuel on the bottom end of the carb...turn the kill switch off kick over bout 5, 6 times with the gas off...then turn it back on see what she does with no choke Quote
OutlawCM85 Posted June 8, 2015 Author Report Posted June 8, 2015 I just tried that but it does the same thing . It acts like it dont want to start even with the choke unless you give it just a slight bit of throttle . I really do appreciate all the help guys . I guarantee this bike wouldn't start at all if it wouldnt have been for all the info I have got from this site . Sent from my SCH-R530U using Tapatalk Quote
OutlawCM85 Posted June 8, 2015 Author Report Posted June 8, 2015 Ok I changed the needle clip back to the middle and played around a little with the air and fuel screws but it wont start without a little throttle . It also wont stay running without the throttle . And the choke doesnt help . It acts like it wants to start if you use the choke but then once you get it running it does nothing . Help please !! I cant wait to test out the top end rebuild !! Sent from my SCH-R530U using Tapatalk Quote
wayne_smith97 Posted June 8, 2015 Report Posted June 8, 2015 Having you tried raising the idle since you went thru the carbs? Quote
OutlawCM85 Posted June 16, 2015 Author Report Posted June 16, 2015 Yes I did try that it did not work . But I tore everything back apart and did the leak down again and it was leaking by the boost bottle . So I fixed that and now I am going to try it again tomorrow . Thanks for the help guys and I will keep you posted !! Sent from my SCH-R530U using Tapatalk Quote
Larry's Shee Posted June 16, 2015 Report Posted June 16, 2015 Yes I did try that it did not work . But I tore everything back apart and did the leak down again and it was leaking by the boost bottle . So I fixed that and now I am going to try it again tomorrow . Thanks for the help guys and I will keep you posted !! Sent from my SCH-R530U using Tapatalk So, what did you have to replace to fix the b bottle leak? Quote
