Metal Shavings in Transmission?
I just rebuilt my motor, everything in the tranny is stock and was reused. I am using the same clutch that came off of the original motor, everything was within spec. I just used normal 10w30 motor oil nothing special and when I went to drain it right after the first ride it had some metal filings in it. Nothing crazy there wasn't any chunks or anything like that. I personally think it is the clutch plates because it doesn't look like steel, its more like brass or something gold colored. I don't know if its normal its my first banshee and I know on chain cases for snowmobiles it is perfectly normal to see some metal filings.
Just glittery specs, the gears look brand new and everything is installed correctly so I doubt the gears are grinding down. Just went for a hard ride yesterday and everything seemed good. Will drain the oil tommorow to see what I find.
