I just rebuilt my motor, everything in the tranny is stock and was reused. I am using the same clutch that came off of the original motor, everything was within spec. I just used normal 10w30 motor oil nothing special and when I went to drain it right after the first ride it had some metal filings in it. Nothing crazy there wasn't any chunks or anything like that. I personally think it is the clutch plates because it doesn't look like steel, its more like brass or something gold colored. I don't know if its normal its my first banshee and I know on chain cases for snowmobiles it is perfectly normal to see some metal filings.
Hmmm, check the brass bushing in the clutch basket and the one in the kicker gear. Just to be sure. Were they filings or just glittery specs? Anything more is no bueno.
Just glittery specs, the gears look brand new and everything is installed correctly so I doubt the gears are grinding down. Just went for a hard ride yesterday and everything seemed good. Will drain the oil tommorow to see what I find.
