tasman_08 Posted April 17, 2015 Report Posted April 17, 2015 I recently bought my banshee and just changed the oil got a lot of shavings and two good chunks of steel. Does anyone have any ideas what these chunks came off of? Sent from my iPhone using Tapatalk Quote
98_sheester Posted April 17, 2015 Report Posted April 17, 2015 Did you ride it with this in? I would pull the clutch cover over and start looking at your kicker gear and transmission do a leak down test see if you have any leaks maybe a crank seal but im sure some others have better advice Quote
bigweav81 Posted April 17, 2015 Report Posted April 17, 2015 Ooh fuck. Sent from your mammy house Quote
bigweav81 Posted April 17, 2015 Report Posted April 17, 2015 That's not a seal. To be honest I've never seen it, or didn't pay attention. Only thing I haven't removed before is the shift forks, and drum...hope it isn't from there. Sent from your mammy house Quote
bigweav81 Posted April 17, 2015 Report Posted April 17, 2015 I just went, and looked at cases I still have split. I'm thinking that's the threads on what I'll call your primary that you mount your clutch basket to Sent from your mammy house Quote
bigweav81 Posted April 17, 2015 Report Posted April 17, 2015 Post up better pics. Or just pull your clutch cover......don't leave us in suspense! Sent from your mammy house Quote
98_sheester Posted April 17, 2015 Report Posted April 17, 2015 Yes pics please its killin us to know Quote
bigweav81 Posted April 17, 2015 Report Posted April 17, 2015 I just went, and looked at cases I still have split. I'm thinking that's the threads on what I'll call your primary that you mount your clutch basket to Sent from your mammy house Mainshaft sounds more appropriate lol Sent from your mammy house Quote
98_sheester Posted April 17, 2015 Report Posted April 17, 2015 There go i been looking around at this case myself looking to see where it came from but i guess now we know Quote
bigweav81 Posted April 17, 2015 Report Posted April 17, 2015 Only thing I see it could be. This will be a post the op never replies back to anyways Sent from your mammy house Quote
tasman_08 Posted April 17, 2015 Author Report Posted April 17, 2015 Pictures coming soon Sent from my iPhone using Tapatalk Quote
tasman_08 Posted April 17, 2015 Author Report Posted April 17, 2015 Taking off clutch cover Sent from my iPhone using Tapatalk Quote
tasman_08 Posted April 17, 2015 Author Report Posted April 17, 2015 Is there any thing I should worry about fucking up when o take this off? Sent from my iPhone using Tapatalk Quote
bigweav81 Posted April 17, 2015 Report Posted April 17, 2015 Shits already fucked up. Drain your gear oil, remove kick starter, slide off. Take pics. You just bought it?welcome to BHQ. Sent from your mammy house Quote
tasman_08 Posted April 17, 2015 Author Report Posted April 17, 2015 https://images.tapatalk-cdn.com/15/04/17/935615d40b2aeaf942466257da582b3e.jpg[/ The gear teeth have the same machining as the pieces that I have but the curvature isn't the same, I don't see anything wrong here, where do I go from here should I take off the other side Sent from my iPhone using Tapatalk Quote
