banshee35027 Posted March 11, 2015 Report Posted March 11, 2015 I need to figure out if my stator is bad. My banshee fires up first kick and idles just fine and reves up good. I can slowly cruise on it and it will be fine but as soon as I lay it down it will fly like I expect it to do. But as soon as I let go of the throttle to come to a stop or turn around I give it some gas and it's like sputtering and won't really go. I can turn it off and it will stop it from sputtering but then I go hard at it again and it will do the same. I know my jetting Is fine because I road it the week before and it road good. I took the stator cover off and there was some water in it from whe. I was ridding the week before. And last week I noticed when I hit a puddle it start to sputter like it does now. Anyways I checked the stator at the plug in where it connects to the harness. The red wire red 15.3 ohms, the green wire didn't read anything at all. White/green and white/red didn't do anything either. So the only one that read anything was the red one. What could be wrong? Quote
hoppedupandcutdown Posted March 11, 2015 Report Posted March 11, 2015 Ignition coil should be 13.7-20.5 Ohms (red to green wire)Pickup coil should be 94-140 Ohms (white/red to white/green wire)Lighting coil should be 0.26-0.38 Ohms (black to yellow wire) Quote
banshee35027 Posted March 11, 2015 Author Report Posted March 11, 2015 Why wouldn't any of the other wires read besides the red one? Quote
sleeper06 Posted March 11, 2015 Report Posted March 11, 2015 Are you talking readings to ground and got that , it's possible that you fried a winding and its grounding out Quote
banshee35027 Posted March 11, 2015 Author Report Posted March 11, 2015 I touch the ground and won't do anything. I touch the red and green to ground and bike shuts off. I got the red to show reading without ground. Quote
banshee35027 Posted March 11, 2015 Author Report Posted March 11, 2015 Just white/green and red/white and Palin green won't do anything. The green wire won't read anything but as soon as I touch ground with it cuts the banshee off. Same thing with red. I got to read the red wire without grounding it or else it cut off Quote
Larry's Shee Posted March 11, 2015 Report Posted March 11, 2015 You test the resistance WITHOUT it running, duh. Output don't matter unless you need to check volts to lights. 1 Quote
banshee35027 Posted March 11, 2015 Author Report Posted March 11, 2015 It was running when I tested it Quote
banshee35027 Posted March 11, 2015 Author Report Posted March 11, 2015 It needs to be tested with it off?? Quote
sleeper06 Posted March 11, 2015 Report Posted March 11, 2015 Yes and please tell me you have a back probe kit and you didn't just stab the wires Quote
banshee35027 Posted March 11, 2015 Author Report Posted March 11, 2015 And if I do need to replace the stator how can I take the flywheel off without the flywheel pulley? Quote
banshee35027 Posted March 11, 2015 Author Report Posted March 11, 2015 Yeah man I gotcha lol. Anyways how can I take the flywheel off with out the pulley? Quote
sheerider11 Posted March 11, 2015 Report Posted March 11, 2015 Yeah man I gotcha lol. Anyways how can I take the flywheel off with out the pulley?You can't. Unless you don't mind destroying your flywheel Quote
