06bluebanshee Posted March 4, 2015 Report Posted March 4, 2015 I just rebuilt my top end. First time starting since rebuild engine fired up right away. The right cylinder was not running as hard as the left one? The right one was firing but not real strong? I took carb off and cleaned it real good. Slides are in right and choke tube on. Bike runs good on the trails, but doesn't have same pressure coming out both exhaust pipes? Any ideas why? Quote
blowit Posted March 5, 2015 Report Posted March 5, 2015 Need to verify slides are balanced or "sync'd". Also if you cleaned the carb but did not remove and specifically clean and visually inspect the pilot jet, start over. That is the source of 90% of these issues... Brandon Mull Engineering 1 Quote
Larry's Shee Posted March 5, 2015 Report Posted March 5, 2015 Try swapping plug wires. Clean nubs on flywheel and set gap. 1 Quote
blowit Posted March 5, 2015 Report Posted March 5, 2015 What he has indicated is "bike runs good" otherwise so I highly suspect one of my two prime suspects. Quote
Luciano Chaidez JR Posted March 5, 2015 Report Posted March 5, 2015 try spark plugs.. i had an issue with mine were my plugs were firing at different rpms. Quote
sick421 Posted March 5, 2015 Report Posted March 5, 2015 Its a bad reed for sure , it happened to me before Sent from my iPhone using Tapatalk Quote
rustygold1 Posted March 7, 2015 Report Posted March 7, 2015 Check park break my friend had it happen to him the sensor was stuck on I guess and it wouldnt spark on 1 cyl Quote
06bluebanshee Posted March 11, 2015 Author Report Posted March 11, 2015 Ok thanks for the help. I will try all of your suggestions when the weather gets nice. Quote
