sand rocket Posted November 25, 2003 Report Posted November 25, 2003 I am looking in to replacing my old clutch lever and perch that has all the old e-brake trash on it. Will the MSR raptor lever and perch work? Or some one tell witch ones will work. In the RM catalog says for motorcycle only. Quote
wheeleymaster99 Posted November 25, 2003 Report Posted November 25, 2003 i'm pritty sure the raptor perch will work raptor and banshees frame are a lot alike Quote
Spank_N_U Posted November 25, 2003 Report Posted November 25, 2003 i just replaced mine but i threw away the packaging. Ill rummage around and see if I can find it. Ill post as soon as i do Quote
Stylemaster Posted November 25, 2003 Report Posted November 25, 2003 i have thje raptor shorty levers on both the banshee and 400ex i love them jsut make sure its adjusted right so your cable doesnt rub and wear all to hell its the most commion mistake installing one of these levers. little expensive but i like them Quote
Leadfoot350 Posted November 25, 2003 Report Posted November 25, 2003 I too am looking to replace all that crap. I want to get a shiny lever and will a tag 2 bar fit the banshee clamp? Quote
evil Posted November 25, 2003 Report Posted November 25, 2003 you can go get a 15 dollar cr perch and lever and modify it to be exactly like the ez pull lever or spend 20 to 25 bucks and get the chrome one. 350, if the bars are standard size then they will fit, if they are the oversize bars like the protapers then you need the big bar adapter or a new stem. later Quote
ledofthezep Posted November 25, 2003 Report Posted November 25, 2003 I'm currently running the MSR raptor perch assy...works pretty good, looks good. But I've had some problems with it...the adjuster on the perch is all alluminum, and strips very easy...kinda hard on the cable too, I just keep it greased to prevent excessive wear. Good thing my stealership seems to like me, cause they've replaced 2 of the adjusters free of charge. If I were to get another, I'd probably get the PEP adjustable perch. Haven't heard anything bad about them, the g/f's shee has one & I like it...have some buddies who have them on their shee's & EX's and they haven't ever had any problems. Quote
BdBanshee Posted November 27, 2003 Report Posted November 27, 2003 I have a MSR Raptor clutch assy. on mine, works fine. I got the standard because with heavy duty clutch springs it gives me more leverage. The standard is quite a bit shorter than the stock lever too. Mine has held up well, I have had it on for a couple of years and finally had to make a new bushing for it where the bolt holds it on. It was getting a bit loose. Quote
KEVPOPPAPUMP Posted November 27, 2003 Report Posted November 27, 2003 I just bought the Applied Racing Ball bearing clutch lever. The "ball bearing" sold me on thinking it would be smooth instead of sandy crusty feeling like the stock one. OH, its smooth, light, and hard as hell to pull especially since I have heavy duty clutch springs! Guess you can't beat the stock heavy lever for better leverage. Maybe next lever will be an easy pull one. I just couldn't find one online. Quote
evil Posted November 27, 2003 Report Posted November 27, 2003 I just bought the Applied Racing Ball bearing clutch lever. The "ball bearing" sold me on thinking it would be smooth instead of sandy crusty feeling like the stock one. OH, its smooth, light, and hard as hell to pull especially since I have heavy duty clutch springs! Guess you can't beat the stock heavy lever for better leverage. Maybe next lever will be an easy pull one. I just couldn't find one online. ILL SHOW YOU HOW TO MAKE THE EXACT LEVER FOR 15 BUCKS INSTEAD OF PAYING 40 FOR A E Z PULL Quote
KEVPOPPAPUMP Posted November 27, 2003 Report Posted November 27, 2003 I just bought the Applied Racing Ball bearing clutch lever. The "ball bearing" sold me on thinking it would be smooth instead of sandy crusty feeling like the stock one. OH, its smooth, light, and hard as hell to pull especially since I have heavy duty clutch springs! Guess you can't beat the stock heavy lever for better leverage. Maybe next lever will be an easy pull one. I just couldn't find one online. ILL SHOW YOU HOW TO MAKE THE EXACT LEVER FOR 15 BUCKS INSTEAD OF PAYING 40 FOR A E Z PULL I'd be interested: tell me what I need to buy and what to do with the parts. That would make a great post for Tips & Tricks! Oh well, after this T-Day in Glamis, my left hand/forearm will be worked out good! Quote
SICK BOY Posted November 28, 2003 Report Posted November 28, 2003 I got a Magnum ez-pull lever brand new in package off ebay for $17.00.I like it alot. Quote
