New to banshees need help
I would still look into all the unsheathed wire getting rubbed around by your clutch cable etc... pay attention to the black wire w/ the white stripe, if that's rubbed through and grounding somewhere it'll shut you down.
Maybe the easy way is to disconnect the harness to the kill/light switch, run it and see if your results change.
It was the clutch cable fixed it with a pipe clamp. Guys just another quick question, was riding it tonight and notice sparks where flying out of my pipes is this normal? Used the search button, but all I could find was some comments that said that when the pipes where really hot sparks will come out, but on mine was when I was barely heating to ride.
Edited by juan_carlos__007
  • 3 weeks later...
