ninjaturtle13
Everything posted by ninjaturtle13
I have not raised any of the exhaust... what would you recomend is a good amount to raise it?.. How about 1 millimeter?... I know ill have more compression without raising the exhaust but maybe I do... how much would be safe to say?
Im ok... how are you with this rain?
Bottom case cleaned
I did the port myself...well... with the port templates...
Are you fuckin serious... why??
Ok... I know this is a sensitive subject but here it goes... I am a mechanic... new to bansheehq... this is it... I have a stock banshee... im doing this to it... stock carbs... boysen carbon fiber reeds... no boost bottle... t6 exhaust... k&n on the carbs... 64.5 bore... stock stroke... welded and trued crank by duncan racing... shift star mod... pancake bearing... new rz clutch... new bearings and seals... fresh bore... 18cc domes... I know what compression ratio to go by... fast trail port by kenoconnor... port windows have only been opened exhaust to 45mm width not height change... intake about 1 mm all around... +4 timing... any ideas??... im at el paso tx about 2500 feet sealevel... i usually run 280 jets on stock carbs.. Im open to all sugestions but amnout of cash almost... any numbers I can change?
New to banshees need help
ninjaturtle13 replied to juan_carlos__007's topic in Banshee Repairs and Mods
You couldnt just take teh end cap off the silencers and just put a piece a screen on it and bolt it back on thats all the spark arrestor is aslong as ur not in a place where USFSApproved stamp is required -
Well what do you have to say in respect of KOC vids of port&polish the shees cylinders.... i have a feeling none of the negative peeps here wouldnt get anything close to wat im doing... i do have scrap ones and will practise on em... if i open up everything a millimeter and jet it accordingly then i couldnt find a reason not to port...
Well... this is exactly the kind of experience I need. I don't mind the money I spend but rather gain knowledge and do it... im a craftsman and enjoy doiung this... yes I have a good quality rotary tool and bits... will do a very good research on how porting works... thank you very much for the motivation HQ
So this is it, i have the description of my bike in. I did this all by myself and now wish to port my banshee by myself. All i want to do is what kenoconnor racing show you in the vid. That would include opening 1mm the exhaust port and 1mm intake ports. Also polish transfer ports and drill the pilot holes. I have no doubt i can cleanly and succesfully do this and also can jet this correctly... do not want this to turn into a trial and error lesson... what other problems might i encounter such as port timing, combustion or what are the normal problms of porting this shee... What does HQ recommend...
What jets are you using? Fill out this form...
ninjaturtle13 replied to vortechblown306's topic in Jetting & Exhaust Forum
1) What type of aftermarket exhaust do you have? T5 2) What type of airfilter do you have? 3 inch kNn type... 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all straight filters 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 3,720ft 5) What size pilot jets are you using? 280 6) What size main jets are you using? 25 7) What temperature is your Banshee jetted for? 80 _100 8) Do you have a port job? no port nor polish 9) What kind of carbs? mikuni 10) What size carbs? stock 26mm mikuni
