The proper way to wash your banshee is to first smoke a joint laced with pcp then sit on your bike as you start tripping balls once you have entered narnia talk to the lion he will then direct you to a goat who will ass rape you. once you come out of your trip you will notice your bike is still dirty thats probably because you spent your afternoon smoking crack instead of just spraying the damn thing off like a normal person.
you can't make this shit up
  • 4 weeks later...
I pull off the air filter and use a zip loc bag with the clamp around the intake to seal out any water. I seal off the exhaust tips with lunch baggies with rubber bands or get the plugs for them. I use hot water with dawn dish soap. Don't use high pressure water. I pre soak the entire bike with simple green. And rinse off than might do it one more time before I start washing with sponge and what not. I take all the plastics off also before I wash. I hate doing it but needs to be done. You want to make sure you rinse the bike very good but no need for high pressure. After I put in gear and lift the front of quad up so its on rear two tires to drain any excess water and wipe dry. Any pockets of water I blow off with compressed air. After wash down I might shoot some new grease in all linkages and armor all the plastic, wheels, seat etc. I will mothers polish the rims and the toomey silencers. This is how I start any project on the quad, tear down or whatever. I do drive through mud and puddles but I just go through them slow. Once I'm back onto the sand I continue to rip. Just that little bit of effort saves me so much time cleaning and the bearings will thank you also. Once I have the machine dialed in, I won't wash it if it doesn't need any looking at or adjusting. I leave it until next ride.
Fuck all that. You armor all your seat? Are you high?
I use a pressure washer. It has a soap spraying tip. Spray it down, wash with the lightest tip. I'm not focusing any spray anywhere.
I'll put rubber gloves over the carb bells and wash the filters seperate. I have fmf exhaust plugs.
Stand the bike up. Pressure wash. Takes all of 3 minutes.
Blow off with a leaf blower.
WD-40 on pipes. Done.
