Deadbeat Posted December 28, 2014 Report Posted December 28, 2014 no idea on the size, i would of thought 5mm, measure the other one Quote
sheerider11 Posted December 28, 2014 Report Posted December 28, 2014 Is it a blind hole or go through the case? Quote
willaduncan Posted December 28, 2014 Author Report Posted December 28, 2014 Is it a blind hole or go through the case? Blind hole Sent from my iPhone using Tapatalk Quote
gusto Posted December 28, 2014 Report Posted December 28, 2014 Well your build sure is lpoking sweet! 1 Quote
willaduncan Posted December 28, 2014 Author Report Posted December 28, 2014 Well your build sure is lpoking sweet!Thanks man I'm excited and can finally see the light at the end of the tunnel. TM Designworks still hasn't shipped my chromoly a-arm sleeves so I can mount up my damn a-arms I'm kinda disappointed in there slow shipping and lack of response Sent from my iPhone using Tapatalk Quote
willaduncan Posted December 28, 2014 Author Report Posted December 28, 2014 And I've gotta pick up some actual paddle tires the ones on are for the ole ladies 4 poke Sent from my iPhone using Tapatalk Quote
salmon_slayer06 Posted December 28, 2014 Report Posted December 28, 2014 sucks screw broke off. I would center punch it as mentioned but make sure you help support that part of the case so it doesn't flex when you start hammering the punch. i would go get a quality drill bit and drill a tiny hole first and work your way up in sizes. I would helicoil it and use some red loctite to keep the coil in place. Sure the hole might be off centered a bit but I don't think it will affect anything. Use some oil when drilling and tapping. Good luck. Build looks good. 1 Quote
Yfzsandaddict Posted December 28, 2014 Report Posted December 28, 2014 Have you tried a left handed drill bit? Quote
willaduncan Posted December 28, 2014 Author Report Posted December 28, 2014 Have you tried a left handed drill bit?The easy out was all left handed Sent from my iPhone using Tapatalk Quote
Yfzsandaddict Posted December 29, 2014 Report Posted December 29, 2014 Yep I've have luck sometimes though with left handed drill bits while drilling the bolt will come out on its own Quote
Man-O-Steele Posted December 29, 2014 Report Posted December 29, 2014 get rid of those shock covers.. they rub throught the paint on the springs and it looks terrible. Quote
willaduncan Posted December 29, 2014 Author Report Posted December 29, 2014 get rid of those shock covers.. they rub throught the paint on the springs and it looks terrible. Really? Sent from my iPhone using Tapatalk Quote
willaduncan Posted December 29, 2014 Author Report Posted December 29, 2014 Does anyone have a way to measure the deflector screws ?? Wanting to make sure I buy the right drill and tap. I'm thinking M4x.7 and a 3.3 mm drill Sent from my iPhone using Tapatalk Quote
willaduncan Posted December 30, 2014 Author Report Posted December 30, 2014 Well if anyone needs the size of the deflector shield screws they measure M5x.08x10 Sent from my iPhone using Tapatalk Quote
willaduncan Posted December 30, 2014 Author Report Posted December 30, 2014 I should have it drilled and re-tapped tomorrow and sealed the case halves!!! Sent from my iPhone using Tapatalk Quote
