mvvette97 Posted November 10, 2014 Report Posted November 10, 2014 I noticed on my banshee that I have to add just a little oil to the tranny sometimes. It's not very much but just a little. I can ride all day and it will stay full but like over a month it will be down a bit. Any idea what could be going on? It doesn't have excessive smoke like it's sucking it through a seal or the cases and I don't see any leaks. Anybody have this problem ever? Quote
trickedcarbine Posted November 10, 2014 Report Posted November 10, 2014 There's a vent on the top of the case at the back motor mount. Could be losing some that way Quote
mvvette97 Posted November 10, 2014 Author Report Posted November 10, 2014 Thanks man. I didn't know that. I will check that out Quote
sheesfast Posted November 10, 2014 Report Posted November 10, 2014 Sounds like your just overfilling it a bit and it's blowing out a vent hose like tricked said. No where else for it to go if it's not leaking or sucking into a bad crank seal. Quote
mvvette97 Posted November 10, 2014 Author Report Posted November 10, 2014 I would assume if it was sucking it through a crank seal then wouldn't it smoke more than normal or even change the color of the plug? 1 Quote
ETR174 Posted November 10, 2014 Report Posted November 10, 2014 It will add some smoke and will act like shit. Quote
sheesfast Posted November 10, 2014 Report Posted November 10, 2014 I noticed on my banshee that I have to add just a little oil to the tranny sometimes. It's not very much but just a little. I can ride all day and it will stay full but like over a month it will be down a bit. Any idea what could be going on? It doesn't have excessive smoke like it's sucking it through a seal or the cases and I don't see any leaks. Anybody have this problem ever? If you're riding all day and not losing any oil, a seal shouldn't be your problem. Quote
mvvette97 Posted November 11, 2014 Author Report Posted November 11, 2014 It is down on the stick just a little after a long day of hard riding but not much. It doesn't seem to be smoking bad or anything and runs great. if it would be the seal can it be changed just by removing the clutch cover and all that stuff or does the case need to be split to get the seal out? Quote
trickedcarbine Posted November 11, 2014 Report Posted November 11, 2014 Crank seals require splitting Quote
mvvette97 Posted November 11, 2014 Author Report Posted November 11, 2014 I'm guessing that's what it is. I'm trying to figure out what all seals and gaskets I need to order so I can get them on their way. I have a 4mil stroker and a guy is telling me i need to order the spacer plate and base gaskets which is supposed to be .060 thick but i just went out and looked and i swear there is not spacer between the jugs and case. Just looks like a single base gasket. Quote
Bennett131 Posted November 11, 2014 Report Posted November 11, 2014 Just order all of the seals, there aren't that many. I recommend using oem ones. Quote
mvvette97 Posted November 11, 2014 Author Report Posted November 11, 2014 well got it torn down and found that the crank seal on the clutch side was junk. So I know for sure what the problem is. Was thinking of just installing a new crank while I am in there. Mine seems fine but since I have it torn down this far I may just do it Quote
Bennett131 Posted November 11, 2014 Report Posted November 11, 2014 So...curious you said there wasn't a spacer plate, correct? Is it ported? Are you sure it's a 4 mil crank? Quote
mvvette97 Posted November 11, 2014 Author Report Posted November 11, 2014 So...curious you said there wasn't a spacer plate, correct? Is it ported? Are you sure it's a 4 mil crank? no there was no spacer plate and yes it's ported. I have the crank out beside me on the floor here and yea its a 4mm long rod. Is what they did was had the domes machined out for the pistons from what I can tell. Here are a couple pics Quote
Bennett131 Posted November 11, 2014 Report Posted November 11, 2014 Then there is no need for a spacer plate. Quote
