 Just looking for some opinions on the topic. Banshee is fine with screaming thru all the gears until it hits 6th and it takes about three times as long as the other gears to top out. Kinda bogs thru the gear but it does get up after awhile. Don't know if its starving for more fuel. I have 13 tooth front 41 back 22 inch tires. Stock carbs, 30 pilot and 330 main jets at 80 ft above sea level.
.30 over bore. +4 timing. Tors eliminated. 20cc cool heads. Herr jugs racing port job. V force 4 reeds. Airbox delete w/ k&n filters. Never checked reading before. What should it be around
Research "plug chop" or 2s "plug reading"
It you are running rich your spark plug will usually be full of gas over the ceramic and it may be wet and full of fuel on the tip. Richness will cause a hesitation before you get into the top end of the powerband. In order to top out in RPMs you may have to give the throttle a couple of good yanks full throttle for it to clear out and reach it.
